How to calculate primary current in an smps transformer?
Younes Thabet
Joined Jan 9, 2019
152
Hello all,
I have the following 12V center-tap transformer with below number of turns, I used (Np/Ns = Vp/Vs) to calculate output but i didn't get 12V although transformer specification says it's 12V.
Can someone point out where I have mistaken?
Also How can I calculate primary current given that this 325V is rectified?
Thanks,
Bordodynov
Joined May 20, 2015
3,433
PLoad=12V*ILoad ==> Icc=12V*ILoad/325V/eff
For example Eff=75%=0.75 ==> Icc=12/325/0.75*ILoad= 0.04923*ILoad
ILoad=1A ==> Icc ~50 mA
Younes Thabet
Joined Jan 9, 2019
152
ILoad = 7.5W/12V=625mA
Eff=82%
so my primary current will be:
Icc=12/325/0.82*0.625=~28mA (too small) !!!!
also: why I am not getting Vs=12V when using Np/Ns = Vp/Vs ==> 325*(5+12)/118=46.8V !!!?
Papabravo
Joined Feb 24, 2006
22,116
Hello all,
Thanks,
The traditional rules for transformers are for sinusoidal inputs. What you are dealing with here is another animal entirely. If you want to get deep in the weeds you can consider the PWM waveform to be composed of a sum of sinusoids and work out what should be happening -- but that seems like a lotta work compared to running a simulation.
Another thing to remember is that traditional AC power transformers are really rotten at handling high frequency PWM signals.
38,948
Okay, that's a flyback converter.
There is a PKIC136 160V Zener/diode clamp circuit across the primary thus the peak primary voltage is 160V, not 325V
(Assuming that the device is shown incorrectly oriented. It should have the Zener facing down with the diode up)
The peak secondary voltage should thus be 160 * 17/118 = 23V, still near double of the stated output.
To determine the primary current we would need to know the duty-cycle of the drive, or the frequency and primary inductance of the transformer.
Younes Thabet
Joined Jan 9, 2019
152
To get a secondary voltage of 12V, primary voltage need to be around 83V !!!
the primary inductance of transformer is 1.6mH (+/- 10%) in 1kHz-1V conditions .. this is what i could get from datasheet of transformer..
Maximum duty-cycle of the TNY276P is 65%..
Younes Thabet
Joined Jan 9, 2019
152
Thank you very much for taking the time to do all these simulations..much appreciated.
I can't say that i fully understand you did there!!
why you used 3.15A fuse !!
although TNY280 is same family as 276P but their differences might affect simulation results!
FYI transformer core is E16.
PLoud =12.1!!! should be 7.5W ..
Anyway thank you very much for your help..
could you please upload/attach simulation files?
Bordodynov
Joined May 20, 2015
3,433
I took the demonstration circuit from the datasheet. I wanted to get 12V and 1A. At the same time these parameters are provided in the universal range of input voltages, namely at American and European standard. I will simulate your circuit with your core. But you will help me if you tell me which winding (what wire diameters). And even better if you tell me the resistance of the windings (especially the primary). If you have a finished transformer and the ability to measure the inductance of the primary and also the primary with a closed secondary. Then I will calculate the real gap in the core. That will be the most accurate calculation. If the clearance is known, it will also be. In the datasheet in the demonstration circuit was the same chip as you use. I have a ready-made spice model similar to your chip, but of an older generation. I think it will do fine since the load characteristics are almost identical.
Younes Thabet
Joined Jan 9, 2019
152
This is all i know about this transformer, hope this could help.
Resistance (mΩ): P = 2200 max | Aux. = 480 max. | S1 = 33 max | S2 = 72 max
Inductance (mH): P = 1.6 mH +/- 10 % at 1 kHz - 1 V
High Potential (kV) at 50Hz: P / Aux =1.5 | P + Aux. / S = 4.0 | P + Aux. / Core= 1.5 | S / Core= 4.0
