How to build traffic light project i want to build it with what logic ??
And copying from the thousands of people that took that class before you and came here for the same help..Using google to search the words "traffic light project" you wrote.
What you said was for the students, but this one maybe not, probably you know the TS and he could be an old member just got banned not long ago, if all his posts are quite normal then it's ok, we will all treat him as normal otherwise a quick ban is waiting.And copying from the thousands of people that took that class before you and came here for the same help..
That project is a big on I guess in schools..
That and elevator floor logic projects..
Like what was always said here....A picture>1000 words.
C'mon, Not even the colors of the LED are shown, the resistor color codes are also there..... unless you're color-blind?ok, this is circuit which color led to use?
I don't think Ritesh's problem is color blindness.C'mon, Not even the colors of the LED are shown, even the resistor color codes are also there..... unless you're color-blind?
The middle led should be yellow, but the color does not yellow enough.C'mon, Not even the colors of the LED are shown, even the resistor color codes are also there..... unless you're color-blind?
Allen
