How to build traffic light control project?
#12
Joined Nov 30, 2010
18,224
You can build a traffic light controller out of anything from relays to microprocessors. I've seen both of them!
Decide where your skills are and start designing.
mcgyvr
Joined Oct 15, 2009
5,394
Using google to search the words "traffic light project" you wrote.
And copying from the thousands of people that took that class before you and came here for the same help..
That project is a big on I guess in schools..
That and elevator floor logic projects..
ScottWang
Joined Aug 23, 2012
7,505
What you said was for the students, but this one maybe not, probably you know the TS and he could be an old member just got banned not long ago, if all his posts are quite normal then it's ok, we will all treat him as normal otherwise a quick ban is waiting.
As you can see that I was told him how to use google, if he can do that then we will be save a lot of trouble.
ScottWang
Joined Aug 23, 2012
7,505
C'mon, Not even the colors of the LED are shown, even the resistor color codes are also there..... unless you're color-blind?
Allen
The middle led should be yellow, but the color does not yellow enough.
And another issue is that the human just very few have the color-blind, almost are the color-weakness.
