Thanks again Bordodynov for your help.
Later today, I will try to play with it and see if i can understand the magic behind and let you know .... as much as i say am good about LTspice as much as i realize that i know nothing about it hahahahaYou can not use them, but use a controlled voltage source (similar to how I used to calculate the "COS")
OhI am sorry.
Wow now I started to understand how you built it.... so, these blocks that I was confused about are behavior voltages sources and that I have to use the assigned values for these behavioral sources including the Vin as well as setting the parameters ... Awesome maaaaaan ... what you did is gorgeous and very helpful .......... now I can easily start analyzing the waves, frequencies and other signals.I am sorry.
