How to block low current?
johnyradio
Joined Oct 26, 2012
615
Is there a way to block current when the load is too low?
Say we have a 60V source.
If the load is pulling 4A. Current should flow.
But if the load is pulling 0.01A, current should be blocked.
When the load increases, then it should be unblocked.
Does this question even make sense?
35,249
It would be more expedient if you told us what you are trying to do, and not "How to block low current?"
For example, can you show us the situation, device, circuit?
johnyradio
Joined Oct 26, 2012
615
How do you determine that the load has increased when current is blocked?
:D Yes, that's what i thought.
It's about triac leakage current.
In my application, I'm passing 5A continuous DC @ 60V. So all devices must be able to handle that.
I need to block current bidirectionally.
Triacs are suited to this, except for one problem. When a triac is open, there's a small amount of leakage current.
When the triac is open, I want to block the leakage current with some component.
When the triac closes, i want to unblock the current.
I don't want to use a mosfet as the blocking device, because too large and expensive. If i use a mosfet as the blocking device, then i might as well discard the triac, and use two back-to-back mosfets. But again, too large and expensive.
Ian0
Joined Aug 7, 2020
13,299
The leakage through a standard triac (BTA16-600B for instance) is <5μA @ 25°C increasing to a maximum of 2mA @ 125°C.
So, is it leakage through the snubber? If so, place the snubber between the triac output and neutral, instead of across the triac.
But triacs are not suited to switching DC, because they can't switch it OFF.
35,249
You can set a limit on the maximum current.
You can set a limit on the minimum current at which point a lower current turns the system off. Now you need a method of turning the system back on when a certain load is detected.
johnyradio
Joined Oct 26, 2012
615
They can switch off if no current is flowing thru the triac. Which is my case.
Why is this small leakage current a problem?
I'm designing a cell switcher which, given two lithium cells, can assemble a battery using one or both cells. This is only for both charging and discharging, so i believe i need to block current in both directions when a switch is open. The connections are such that, if just one cell is switched into the circuit, then any leakage will flow from both terminals of both cells to both terminals of both cells. The dotted line shows the leakage path.
The leakage through a standard triac is 2mA @ 125°C.
Maybe that amount of leakage is ok for this application.
johnyradio
Joined Oct 26, 2012
615
Not exactly an efficient circuit if you are charging a 3.7V lithium cell and losing 1V across the triac.
For my purpose, efficiency doesn't matter. Low parts-count matters.
Triacs block in both directions, which i need. Mosfets only block current in one direction, so i'd have to use two back-to-back mosfets, doubling my parts count.
TRIACs only work with AC, not DC.
i believe you're incorrect.
Ian0
Joined Aug 7, 2020
13,299
Which is my case.
you mean, triacs aren't legal in Europe?
A triac switching 230V loses 1V. Efficiency = 229/230 = 99.6%
Efficiency switching 3.7V = 3.7V/4.7V = 78.7%
There may be regulations about the overall efficiency of the appliance. You will have to check.
johnyradio
Joined Oct 26, 2012
615
If you have something that stops the current, then what does the TRIAC do?
  1. Circuitry external to this question stops current going to triac.
  2. Then the triac in this question will open. There's no current, so it can do that.
  3. Then circuitry external to this question will turn current back on, allowing current to flow to other parts of the circuit. The triac in this question will block current in it's localized region of the circuit.
