how to bias a jfet right
Ghina Bayyat
Joined Mar 11, 2018
148
hi i have question
i know that a n-channel jfet needs a negative voltage on its gate to operate but i found on many sites a jfet circuit with a voltage divider biasing network just as a npn common emitter circuit
how could it possibly work like this ??
isn't it supposed to be biased like this circuit :
can u please tell me which one is the right one and if they are both right how can the first circuit be able to bias the gate at a negative voltage ??
AlbertHall
Joined Jun 4, 2014
12,624
They are (or could be, depending on values) both right.
The gate needs to be negative of the source so in the second circuit the gate will be at some positive voltage but as long as the source is at a higher positive voltage then the gate will be negative of the source.
Ghina Bayyat
Joined Mar 11, 2018
148
I get it now so the gate doesn't have to be realy negative but more negative than the source
and if i have a dual rail supply voltage like a battery i should rise up the source voltage by using the resistor Rs right ??
This means that i should choose Rs to be greater than Rg2 ??
38,484
Why does everyone say "n-channel"? I understand its a field effect unipolar transistor, but that is not a good excuse for me.
"n-channe" == npn
"p-channel" == pnp.
Because those are not equivalent.
npn and pnp are not descriptions of field-effect transistors, they are descriptions of bipolar junction transistors.
That's why everyone says n-channel (or p-channel) for junction FETs. :rolleyes:
ian field
Joined Oct 27, 2012
6,536
hi i have question
how could it possibly work like this ?? isn't it supposed to be biased like this circuit :
Its pretty much the same as a thermionic triode with suitably proportioned voltage levels.
The divider bias method sometimes pops up in older "circuit compendiums", I've never seen an explanation for it. Maybe necessary in the top section of a cas-code stage though.
OBW0549
Joined Mar 2, 2015
3,566
Using a voltage divider to bias the JFET's gate a bit above ground allows the source resistor, Rs, to do a better job of stabilizing the circuit's operating point. Without it, drain current is entirely dependent on the JFET's characteristics, and both Idss and Vgs(off) can vary by 3:1 or even more from unit to unit.
Because of the spread in characteristics, JFETs are notoriously tricky to bias in a consistent, repeatable way-- which is a big part of the reason you don't see them used more often.
