How to ad 2 momentary switches back/forward or single dpdt momentary switch to the remote controller to control reversing motor, the remote control must be at momentary mode too. I want to control the motor separately by remote control or by momentary switch/switches.
I have upload 3 circuits.
The 1st is momentary dpdt switch connected to the input
power and to the motor, result: smoke, hot wire, fire.
The 2nd one is momentary dpdt switch connected to the COMA pins of the remote controller, The result: remote control power can't go to the motor because of the momentary dpdt switch is on stop position. Dpdt switch doesn't have any power to control the motor.
In order to control the motor the remote control and the dpdt switch have to be pressed at the same time, which is not good!
The 3d circuit is for you to continue to make your fix circuit...
power and to the motor, result: smoke, hot wire, fire.The 2nd one is momentary dpdt switch connected to the COMA pins of the remote controller, The result: remote control power can't go to the motor because of the momentary dpdt switch is on stop position. Dpdt switch doesn't have any power to control the motor.
