Hello
I found this circuit in LT1012 application notes pdf, and i cant understand how it works.
In usual trans impedance amplifier where current to be measured goes through negative input resistor, the op amp is trying to have zero volt different between its inputs, so it uses a feedback path to satisfy that making its output going negative. But here, i see a capacitor in the feedback, and a transistor that makes something similar.Why a transistor there?
Also, are Q1/Q2 here some kind of current mirror?. What role Q4 has? Adding +0.6V to op amp output? I see LT1004 fixes 1.2V for the different scales measuring resistors, but is confusing that adding Vbe decrements for Q3/Q2/Q4 path I get 1.8 at least..(unless Q4 goes off at some point)
What a mess for a poor hobbist like me...
Could somebody help please?
