Yes I am the author and have access to the code. How do you do white box testing? Do you use any tools/techniques/strategy etc...?Since this is in the Programming forum, I assume you're talking about testing software.
If you're the author or have access to the code, the typical method is to do white box testing. If you don't have access to the code, you do black box testing.
http://softwaretestingfundamentals.com/differences-between-black-box-testing-and-white-box-testing/
Queue_ptr ptr = CreateQueue();
check_condition(ptr->num_elements == 0);
// More tests follow
Clean and simple explanation, thanks a lot for the reply!!So, for example, the Queue discussed in the other thread would be tested by creating queues, inserting and removing, and measuring the results as the harness executes.
C:Queue_ptr ptr = CreateQueue(); check_condition(ptr->num_elements == 0); // More tests follow
Thanks for the reply, I think that's a good idea!It's good if the person who developed the code is NOT the person writing all of the tests. Write some of the tests for areas that you think are susceptible to errors over time, but have someone else write some too.
You generate data to test every statement/branch in the code.Yes I am the author and have access to the code. How do you do white box testing? Do you use any tools/techniques/strategy etc...?
uint32_t iBigNumber = GetSomeResultExpectedToBeSmallerThan255FunctionReturns32bitResult();
ASSERT(iBigNumber <= 255); // Debugger will stop here if iBigNumber > 255
uint8_t iSmallNumberToPassTo8BitProcessor = (uint8_t)iBigNumber; // This would run but might cause unexpected output that is difficult to track down if number is > 255
002086E0 E92D41F3 * push { r0, r1, r4, r5, r6, r7, r8, lr }
002086E4 E1A04002 * mov r4, r2
002086E8 E1A06000 * mov r6, r0
002086EC E1A08001 * mov r8, r1
002086F0 EBFFF9DD * bl 206e6c ;
002086F4 E3540000 * cmp r4, #0
002086F8 C3500000 < cmpgt r0, #0
002086FC D3A05001 > movle r5, #1, 0 ; 0x00000001
00208700 C3A05000 < movgt r5, #0, 0 ; 0x00000000
00208704 D3A04000 > movle r4, #0, 0 ; 0x00000000
00208708 DA00001B > ble 20877c
0020870C E1A07000 * mov r7, r0
00208710 E28D0004 * add r0, sp, #4
00208714 EBFFFD3D * bl 207c10
00208718 E1550008 * cmp r5, r8
0020871C AA000005 x bge 208738
00208720 E5963000 * ldr r3, [r6]
00208724 E28D0004 * add r0, sp, #4
00208728 E7D31005 * ldrb r1, [r3, r5]
0020872C EBFFFD67 * bl 207cd0
00208730 E2855001 * add r5, r5, #1 ; 0x1
00208734 EAFFFFF7 * b 208718
00208738 E0844008 * add r4, r4, r8
0020873C E1540007 * cmp r4, r7
00208740 AA000005 x bge 20875c
My assembly is very limited, but I am interested on what tool you use to get those information?Similarly when undertaking a very thorough unit testing activity I'll shoot for "logic coverage", i.e. making sure all of the branches in the emitted assembly language are fully covered.This listing was generated after some test cases have finished. The asterisk indicates an instruction has been run. < and > indicate a conditional has been executed but only one of two conditions were seen. The x indicates both conditions (true and false) were covered.Code:002086E0 E92D41F3 * push { r0, r1, r4, r5, r6, r7, r8, lr } 002086E4 E1A04002 * mov r4, r2 002086E8 E1A06000 * mov r6, r0 002086EC E1A08001 * mov r8, r1 002086F0 EBFFF9DD * bl 206e6c ; 002086F4 E3540000 * cmp r4, #0 002086F8 C3500000 < cmpgt r0, #0 002086FC D3A05001 > movle r5, #1, 0 ; 0x00000001 00208700 C3A05000 < movgt r5, #0, 0 ; 0x00000000 00208704 D3A04000 > movle r4, #0, 0 ; 0x00000000 00208708 DA00001B > ble 20877c 0020870C E1A07000 * mov r7, r0 00208710 E28D0004 * add r0, sp, #4 00208714 EBFFFD3D * bl 207c10 00208718 E1550008 * cmp r5, r8 0020871C AA000005 x bge 208738 00208720 E5963000 * ldr r3, [r6] 00208724 E28D0004 * add r0, sp, #4 00208728 E7D31005 * ldrb r1, [r3, r5] 0020872C EBFFFD67 * bl 207cd0 00208730 E2855001 * add r5, r5, #1 ; 0x1 00208734 EAFFFFF7 * b 208718 00208738 E0844008 * add r4, r4, r8 0020873C E1540007 * cmp r4, r7 00208740 AA000005 x bge 20875c
Based on what you see there are conditional branches that have not been covered by the test cases and therefore my work is not finished.
I thought you only need to disable the interrupts when updating the none atomic variables use inside and outside the interrupt? The none atomic variables are OK if they are used outside the interrupt. (Assuming necessary registers are saved and restored on entry and exit interrupt)The type of testing needed also depends on the code.
I wrote some code for Arduino where I was using multiple timer interrupts and I made sure I disabled interrupts when variables longer than a byte were being updated.
Interrupts are disabled by default within an interrupt service routine, so you wouldn't normally need to disable interrupts when updating non-atomic variables in an ISR. But you need to do it everywhere else. If you forget to do that, you'll be faced with some very difficult to debug problems.I thought you only need to disable the interrupts when updating the none atomic variables use inside and outside the interrupt?
That is what I am trying to say:Interrupts are disabled by default within an interrupt service routine, so you wouldn't normally need to disable interrupts when updating non-atomic variables in an ISR. But you need to do it everywhere else. If you forget to do that, you'll be faced with some very difficult to debug problems.
/* Assuming a 8-bit architect like AVR */
volatile uint16_t var_isr; /* use inside and outside ISR */
uint16_t var_normal; /* use ouside ISR only */
Interrupt someISR(){
SaveAffectedRegisters();
var_isr++; /* update variable */
RestoreAffectedRegisters();
void main(){
for(;;){
/*! it need to has atomic access as it's
* updated inside an ISR
ISR_DIS();
var_isr = var_isr * 2;
ISR_EN();
/*! This does not has atomic access as it's
* not used inside any interrupt. It's accessed
* outside ISR only
var_normal = var_normal * 2;
That's what I'm trying to say too. If you wanted to change var_isr in someISR(), you wouldn't need to disable interrupts because they're disabled by default.That is what I am trying to say:
That's a hell of skills!That specific one is an ARM simulator I wrote for my own purposes. No, you can't have it.
The coverage features I added were based on my experience years ago with a Z8000 simulator we used developing commercial avionics. I don't recall where it came from; it may have been developed in-house, or purchased.
So you implement all the registers as of a real physical device and memory spaces, that is pretty cool! Do you have something to simulate the IOs as well?you create implementations for all of the instructions the disassembler recognizes, operating on the memory spaces and registers.
Mute BMW head unit | Analog & Mixed-Signal Design | 32 | ||
L | Lighting driver unit: traffic lights | Homework Help | 9 | |
K | Unit Testing - C | Programming & Languages | 21 | |
G | Light flashing unit for car | General Electronics Chat | 133 | |
Q | testing MPU (Magnetic pickup unit) | General Electronics Chat | 9 |
by Don Wilcher
