How OSI model work in the real world?
mukesh1
Joined Mar 22, 2020
68
Why we use OSI reference model and how does the OSI model work in the real world?
Let's say I have made a development board which has a microcontroller, inbuilt bluetooth module, wi-fi module and ethernet module.
When i will send data from board to pc via uart with RS232 interface. Does it come in physical layer?
What can I do with my board, which comes in physical layer and data link layer
drjohsmith
Joined Dec 13, 2021
1,650
OSI is a model
a standard that allows us all to talk in the same language ,
with the same boundaries ,
You ask about physical layer
what do you know about the physical layer and the OS model
mukesh1
Joined Mar 22, 2020
68
Seems like you have answered your question
The description of each layer is given in many documents but it is very difficult to understand it from real example.
I really don't understand Why we use OSI reference model and how does the OSI model work in the real world?
drjohsmith
Joined Dec 13, 2021
1,650
Like all official specifications
its very verbose
At least now there are many over view docs on line,
e.g.
https://www.forcepoint.com/cyber-edu/osi-model
https://www.computernetworkingnotes...ven-layers-model-explained-with-examples.html
At the end of the day,
the basis is that any layer talks to its same layer, and does not care how the upper or lower layers are handling things,
So if you have an application that talks say session layer, then any session layer will understand it,
no matter what trans port layer it is ,
So TCP/IP packets can be sent over phone lines, radio, satellite, fibre,
the session layer does not care.
Which bit do you not get ?
