How much amps do I need
ericgibbs
Joined Jan 29, 2010
21,592
hi,
OK,
As you have 3*3.7v batteries in series, that's a nominal 11v, do you have a 'buck module for the ESP32's 3.3V.?
What are the voltage/currents of the motors and servo's.?
E
valdrian
Joined Jun 7, 2023
16
hi,
OK,
E
I have a stepdown module I'm planning on using 4 batteries on series
valdrian
Joined Jun 7, 2023
16
hi,
OK,
E
for the motors they are 5v motors and I'm using sg90 servos
ericgibbs
Joined Jan 29, 2010
21,592
hi,
In order to suggest how much current you need or your project, we need to know the current loading of the motors/servo's etc.
E
also the rating of your step down module,
ElectricSpidey
Joined Dec 2, 2017
3,362
Batteries in series = higher voltage.
Batteries in parallel = higher current.
More batteries = more power.
You will probably need a series /parallel configuration.
Will your motors tolerate 8 volts?
Will your motors run ok on a voltage lower than 5?
valdrian
Joined Jun 7, 2023
16
Actually I don't know I'm running one of those small motors with gearbox, there are no info on the current load just the
valdrian
Joined Jun 7, 2023
16
hi,
E
The step down module is lm2596 and is rated 4.5v - 35v to 1.25 - 30v with maximum current 3 amps
I'm using sg90 servos, from the data sheet the stall current is 650±80mA
I don't know what current loading is
valdrian
Joined Jun 7, 2023
16
hi,
OK,
E
hi,
OK,
E
How much current can a 18650 produce?
35,227
Can it produce 5 amps?
I have no info of the discharge rate
A quick search shows 18650 battery ratings of 3.7V with capacity ranging from 1200mAh to 9800mAh.
Let us take a typical rating of 2200mAh = 2.2Ah.
Theoretically, that means it can supply:
2.2A for 60 minutes
4.4A for 30 minutes
13A for 10 minutes
That's the theory. In practice, your mileage will vary, besides the fact that the battery will get very hot and likely to burst into flames.
valdrian
Joined Jun 7, 2023
16
2.2A for 60 minutes
4.4A for 30 minutes
13A for 10 minutes
That's the theory. In practice, your mileage will vary.
Ok thank you
