how many times can TSM102 amplifiers achieve?
LAOADAM
Joined Nov 21, 2018
956
If use two of its amplifiers + one of its comparators, totally how many times amplify can get? in this case, can the other one Comparators still function?
Adam
35,025
It depends on your signal frequency.
Look at the Gain vs Frequency curve (Figure 6) in the data sheet.
And it depends on your supply voltage. The output voltage cannot exceed the supply voltage.
LAOADAM
Joined Nov 21, 2018
956
Thank you MrChips.
The signal is DC, ~10 mV, .checked the Figure 6, seems db about 50?
My supply voltage is 12Vdc, can I consider 50*50*50 total db?
35,025
You add dB. Hence two amplifiers of +50dB each would be +100dB which is a gain of 100,000.
10mV x 100,000 = 1000V. You cannot get this from a 12VDC supply.
