How many MCP3008 can be interface with Pi
Fanfire174
Joined Mar 13, 2018
240
Hello everyone
We can connect eight temperature sensor's with one MCP3008. if I have 12 devices and I want to measure their temperature so I need 12 temperature sensor's to measure temperature of each device. I don't know How many MCP3008 need be interface with Pi to measure temperature of 12 devices
I found it on the internet, that it depends on the address of ADC MCP3008 But I do not understand how many MCP3008 need to measure temperature of 12 devices ?
bertus
Joined Apr 5, 2008
23,001
When you use single ended inputs, you will need two MCP3008's.
When you use differential inputs, you will need three MCP3008's.
You can select the MCP3008's using the CS input.
Bertus
Fanfire174
Joined Mar 13, 2018
240
so selection of adc depends on the CS input
Raspberry pi3 have 26 GPIO pins available
How many MCP3008 can be interface with raspberry PI 3 ?
Ian Rogers
Joined Dec 12, 2012
1,136
So selection of adc depends on the CS input
Not entirely.... The ADC module channels are selected by software you would select the first ADC module and traverse the channels reading each in turn ( or which ever order you want ) then select the second...
Unfortunately, this is a single ended ADC only! so all eight are available on each chip..
After the clock, SDO and SDI you need a CS pin for each ADC IC so...… Loads...
**** Whoops Apologies Bertus…. This device does support differential sampling!!!
Fanfire174
Joined Mar 13, 2018
240
Let's take one example There is a company that has 220 devices and I have to know the temperature of each device. I have make a system that can measure the temperature of each device.
I need to purchased raspberry pi, temperature sensor and MCP3008 to make whole system.
I think I have to purchased 220 temperature sensors. I don't have any idea for raspberry pi and ADC
How many raspberry pi and MCP3008 need to make whole system ?
