The function of a resistor is to resist voltage. There will always be a voltage drop across a resistor. If there is a resistor, someone wanted a lower voltage on the other side of it. Since voltage and current (amperage) are inextricably linked, it is often the case that a resistor is put there to limit current.Hello,
I show one schematic and they give 6v Supply using the battery but in output they put 1M and 220k resister after pass the next step output why then put some resister ?why not directly pass the output on the circuit?
Thanks & Regards
Yash Shah
