I need to decide on a microcontroller
cmbasak
Joined Dec 14, 2022
I need to decide on a microcontroller with Bluetooth.
the microcontroller would control one micro-miniature solenoid valve on and off, and also regulates one resistor (on and off), Bluetooth will be used to connect to a cell phone which would be used to control the valve and resistor.
The problem is power source is very small 3.7 V
Can you please suggest the smallest and lightest microcontroller for my use case?
Puck.js I can start but I feel a lot of unnecessary things for my purpose make it expensive.
Also Ardreno does not have a Bluetooth built in and the size is too big anyway.
Papabravo
Joined Feb 24, 2006
22,111
Hello and welcome. I'm not familiar with the concept of "regulating" a resistor. Can you elaborate on this? Also could explain the reference to Puck,js? What is that?
camerart
Joined Feb 25, 2013
3,853
Hi P,
Look into these:
https://www.alldatasheet.com/datasheet-pdf/pdf/74968/MICROCHIP/PIC16F628A.html
https://www.ebay.co.uk/itm/282326689518
https://www.aliexpress.com/item/325...00029758632388!sea&curPageLogUid=k1PqW63cfsu8
C
