Hi everyone. I don't know English very well, so I use a translator. In short, this TV broke down, presumably an automobile one. When power is applied, it does not react in any way, although I pressed all the buttons that it has. I checked and soldered the capacitors, checked the voltages, but nothing helps. The only thing I noticed is that the high voltage capacitors don't charge. The TV is powered by 12 volts, even it is written on the board. I really need it and I want to fix it. Thanks in advance.
