how does work this font8x8
michael1978
Joined Jun 29, 2014
309
hi
can somebody explain me, how does work this
[5:0] char_row = row_addr[8:3];
[2:0] font_row = row_addr[2:0]; //char row 8x8
[6:0] char_col = col_addr[9:3];
[2:0] font_col = col_addr[2:0]; // char col 8x8
this 8X8 font but the address [8:3] for row and adress for col [9:3], what does do this bit 4 in row and column
djsfantasi
Joined Apr 11, 2010
9,237
Wow, time for the crystal ball again.
What are the definitions of all those data structures? Without that, it’s like asking a question about a foreign language, without knowing the language.
dè an ifrinn a tha thu a ’bruidhinn?​
Since we have no clue as to how row and column are defined, I can’t help tell you how anything affects bit 4.
michael1978
Joined Jun 29, 2014
309
module display_scan_codes (sys_clk,clrn,ps2_clk,ps2_data,r,g,b,hs,vs,
vga_clk,blankn,syncn); // display key scan codes
input sys_clk, clrn; // sys_clk: 50MHz
input ps2_clk, ps2_data; // kbd clk and data
output [7:0] r, g, b; // vga red,green,blue colors
output hs, vs; // vga h and v synchronization
output vga_clk; // for ADV7123 VGA DAC
output blankn; // for ADV7123 VGA DAC
output syncn; // for ADV7123 VGA DAC
wire font_dot; // font dot
wire [31:0] inst,pc,d_t_mem,cpu_mem_a,d_f_mem;
wire write,read,io_rdn,io_wrn,wvram,rvram,ready,overflow;
wire [7:0] key_data; // kbd code byte
// vga_clk
reg vga_clk = 1;
always @(posedge sys_clk) begin
vga_clk <= ̃vga_clk; // vga_clk: 25MHz
end
// vgac
assign blankn = 1;
assign syncn = 0;
wire [8:0] row_addr; // pixel ram row addr, 480 (512) lines
wire [9:0] col_addr; // pixel ram col addr, 640 (1024) pixels
wire vga_rdn; // in vgac, rd_a = {row[8:0],col[9:0]}
wire [23:0] vga_pixel = font_dot? 24’hffffff : 24’h0000ff; //white/blue
vgac vga_24 (vga_clk,clrn,vga_pixel,row_addr,col_addr,vga_rdn,
r,g,b,hs,vs);
wire [5:0] char_row = row_addr[8:3]; // char row
wire [2:0] font_row = row_addr[2:0]; // font row
wire [6:0] char_col = col_addr[9:3]; // char col
wire [2:0] font_col = col_addr[2:0]; // font col
// char ram, 640/8 = 80 = 64 + 16; 480/8 = 60;
wire [12:0] vga_cram_addr = (char_row<<6) + (char_row<<4) + char_col;
wire [12:0] char_ram_addr = wvram? cpu_mem_a[14:2] : vga_cram_addr;
reg [6:0] char_ram [0:4799]; // 80 * 60 = 4800
wire [6:0] ascii = char_ram[char_ram_addr];
if (wvram) begin
char_ram[char_ram_addr] <= d_t_mem[6:0];
end
end
// font_table 128 x 8 x 8 x 1Input/Output Interface Controller Design in Verilog HDL 477
wire [12:0] ft_a = {ascii,font_row,font_col}; // ascii,row,col
font_table ft (ft_a,font_dot);
// ps2_keyboard
ps2_keyboard kbd (sys_clk,clrn,ps2_clk,ps2_data,io_rdn,key_data,ready,
overflow);
// cpu
single_cycle_cpu_io cpu (sys_clk,clrn,pc,inst,cpu_mem_a,d_f_mem,
d_t_mem,write,io_rdn,io_wrn,rvram,wvram);
assign d_f_mem = io_rdn? {25’h0,ascii} : {23’h0,ready,key_data};
// instruction memory
scinstmem_make_code_break_code imem (pc,inst);
endmodule
ErnieM
Joined Apr 24, 2011
8,415
I am not very good at guessing games so I asked my magic 8 ball.
My magic 8 ball said it has no idea what this code might be connected to.
What language? What micro? What display?
How are they connected?
