I'm curious about the nature of reverse voltage failure modes. Is it literally the amount of reverse voltage that does the damage, regardless of current flow? Or is it that reverse voltage beyond a certain limit causes reverse current flow - perhaps at unregulated levels - which in turn rapidly builds heat and causes damage that way.
I'd really love to know if there's any answer to these questions in a general sense, or perhaps a small number of different answers depending on the scenario (like cmos fails one way, but ttl fails another.)
In case there aren't any such simple answers, here are two specific parts I'm interested in understanding:
MCP6542:
http://www.microchip.com/wwwproducts/en/MCP6542
SS495a:
https://www.digikey.com/catalog/en/partgroup/ss495-series/12446
I use both of these chips on a board we produce quite a lot of, and I failed to include reverse voltage protection in my original design. The 5 boards that I know have been exposed to reverse voltage (-5VDC) all seemed to handle it just fine, and appear to work properly when fed proper voltage, but I'm not sure if they should be trusted now. The 5V supply that feeds them is limited to 80mA, and I've wondered if that current limit plays a role in the boards' survival.
MCP6542:
SS495a:
