I was able to use a Fluke multimeter from work but I’m not sure of the readings.
I access the VSS wire is at the gauge cluster wire harness.
If you have the upgraded radio its also an 8 pulse 5V signal wire at the gauge cluster and in one of the radio wire harnesses.
With a basic radio it’s only a two pulse signal at the gauge cluster so that’s 2 pulses for each rotation of the wheel? Should I see the voltage on for a ¼ turn and off for the next ¼ turn?
DC or AC I was only able to read a few mV. It did increase in scale with the speed of the truck. The best setting on the Fluke was AC with the Hz function on. This gave me half the MPH in Hz. So at 10 MPH, 5Hz was displayed and then 20 MPH was 10Hz and 40 MPH was about 20Hz. This seems incorrect as the Nissan manual states that we should see 240Hz at 12 MPH???
