Here's a video on Casing and Cementing of off-shore wells
Even with cameras, once they pull up the drill string each time, how are they lowering it and getting it back in the hole each time ? (at the beginning, they do add casing pipe later, between the bottom and water surface) The water can be so deep that the drill-string will sway in the currents quite a bit I'm sure. So what sort of robotic thing is on the ocean floor to catch it, without getting smashed, and then put it back in the drill hole each time ? What year did they start under-water drilling ? Gravity alone might get you close to a 2ft target on the sea-bed, or lake-bed, in shallow water, but it won't stop you from missing or smahing up the "christmas-tree" once that's in place. And if the water is 1,000s of feet deep, the deflection angle can be pretty big, and what catches the drill-string without getting crushed ? So how do they do it ?
this video doesn't even mention the risk, every single time, of smashing the thing they place on the bottom
