how Do I make a circuit simular to compressor?
Nikan.Parvini
Joined May 31, 2017
13
Hi guys,
This is my first post so bare with me. So I'm working on a project that requires a small amount of compressed air to be released on the touch of a button when needed. I originally went down the mechanical route, as this is my background, but soon realised I could utilize a micro 3v air pump and solenoid valve to release the air. The problem I have is that I need the micro pump to turn on for x amount of time to get pressure in the system, then turn off. I need it to be like a tiny compressor and keep topping up the air pressure every time the solenoid releases some. I'm guessing that some form of pressure sensor needs to be incorporated into the system or I can just time how long it takes to get to the pressure needed then set the pump to turn on for that amount of time, but not sure how to get it all to work together. So just to clearly outline the system I need :
1. 1.5-6V 130mA dc micro air pump turns on until 5-10 psi (call it 5 for now) is achieved.
2. once 5 psi is achieved the pump turns off.
3. push button is pressed and the solenoid valve opens for a set amount of time (I would like to be able to alter the time here as well if possible).
4. after a set amount of time the solenoid valve closes
5. back to stage 1.
There will be a minimum of 15 seconds between button presses (pressure drop). Its just like a compressor but using components like those used in a blood pressure monitor (micro pump, solenoid valve etc.)
So any ideas on how I can go about this guys? Please remember that I'm a lathe/milling machine type of guy not a resistor capacitor guy so as basic as possible please folks.
bertus
Joined Apr 5, 2008
22,925
Is there a one way valve between the pump and measuring point of the pressure?
When the pump shuts off and there is no one way valve, the pressure might leak away through the pump.
At what rate will the pressure be released by the valve?
Bertus
Nikan.Parvini
Joined May 31, 2017
13
Bertus
hi there, thanks for your reply, yes there will be a one way valve after the pump and i believe the solenoid valve releases somewhere around 5l/m,
bertus
Joined Apr 5, 2008
22,925
What is the volume of the 5 psi holder?
When there is 5liter/min and you want 15 seconds flow until no pressure, the holder must have a minimum volume of 5 liter / 4 = 1.25 liter.
Bertus
Nikan.Parvini
Joined May 31, 2017
13
Bertus
the volume will be around 10-20ml and the release time should be fractions of a second
bertus
Joined Apr 5, 2008
22,925
When the valve has a flow of 5 liter / min and you want to release 2 ml , the time is only 24 mSec.
How fast can the valve switch?
Do you have the specifications?
Bertus
Nikan.Parvini
Joined May 31, 2017
13
Bertus
i cant seem to find that info at the moment do you know if they make mini solenoid valves that act that fast?
Nikan.Parvini
Joined May 31, 2017
13
Perhaps then a restriction to lower the flow may help.
That way you can stretch the opening time.
Bertus
my thinking was that a normally closed solenoid valve when energized would open then as soon as you cut the power the valve closes again? so energize for 25 milliseconds then turn off to close (25 to allow time for valve to close)
bertus
Joined Apr 5, 2008
22,925
Depends on the construction of the valve.
There are also two way valves that will switch between two ports.
Show a datasheet of the intenden valve you want to use.
Bertus
Nikan.Parvini
Joined May 31, 2017
13
Bertus
it says when the power is on the valve is open and when the power is off the valve closes
