How do i figure out which wire of this motor is positive?
meth
Joined May 21, 2016
325
Motors dont really have positive and negative input, they can rotate CW or CCW depending on the voltage... so the worst thing that can happen is your motor to rotate in opposite direction..
Ian0
Joined Aug 7, 2020
13,310
I took apart this Corning pc-420 hotplate stirrer without recording which wire goes where. Unfortunately there's no schematics online for these models. How do i figure out which wire of this motor is positive and negative?
Neither.
It's an AC motor. Looks like a shaded pole motor to me but @MaxHeadRoom will confirm, in which case it will have a fixed direction of rotation depending on the position of the shading rings.
MaxHeadRoom
Joined Jul 18, 2013
30,873
Neither.
Yup, shaded pole, you can see the two shorted turns.
Cheap form of AC motor, but not too efficient! :oops:
The only way to reverse it is to swap the armature end for end.
The motor shade-pole is an inefficient way to generate a second phase of EM field energy from a single phase supply. That second phase provides the rotational vector to start the shaft spinning.
