Help figure this beeper circuit out
ThePanMan
Joined Mar 13, 2020
953
My cousin and I are scrapping an old dash board gauge cluster from a Gen 2 Tacoma. There's a beeper we pulled off the board and this is the associated circuitry that seems to go with it:
We don't know what or where some points of contact go, so we are assuming what's marked as "GND Plane" could be a ground or it could be a power plane. We don't know and can't test it. Can anyone make sense of this thing?
Here's a schematic of what we can guess may be the circuitry:
Q4 designator is just that - a possible transistor. But what kind - we don't know. Figure it might be an interesting discussion. Or could just be more junk for the scrap bin. We're not even sure about the transistor pin-out.
AnalogKid
Joined Aug 1, 2013
12,295
Please post a photo of the beeper. It probably has a 1-transistor circuit inside so it doesn't need a drive waveform, just switched DC at the beep rate.
ak
ThePanMan
Joined Mar 13, 2020
953
There is no "insides" that I can take a picture of. In order to open it I'd probably have to crack the glued seam.
AnalogKid
Joined Aug 1, 2013
12,295
Based on your schematic, my guess is that the input to R88 is a 2 kHz squarewave, the GND is vehicle chassis ground, and the beeper connects to switched or continuous vehicle power (+12 V).
It will help to understand the circuit if you re-draw your schematic in a more conventional manner. Power up, GND down (always), inputs from the left, outputs to the right.
ak
ThePanMan
Joined Mar 13, 2020
953
Makes sense if this is the correct configuration:
We will be redrawing this schematic, but sghioto has already drawn what is probably a better representation of what we're dealing with.
The reason why the "Unknown voltage" "Possible 5VDC" is because the car's computer has a 5V source for other sensors. We don't know this for a fact, it's all guesswork. And since we can't get a schematic of the gauge cluster and the chance that the board is 4 or more layers we can't begin to guess where the circuitry goes, or what voltages or signals may be controlling it. We're not even sure the ground is actually a ground. It might be. But we know nothing beyond what has been presented.
ThePanMan
Joined Mar 13, 2020
953
Any voltage readings possible?
No. In order to get a reading we - (my cousin) - would have to have the vehicle this came out of - which he doesn't. Remove whatever dash was in there at the time and plug the unit into the vehicle for a reading. Readings would likely need to know if what we think is a ground - IS - a ground - or not. What voltage is where and if there's a signal such as a seat belt warning or something. There would be a lot of work just to get a voltage.
My cousin thinks ( I disagree ) the cap and resistors should generate a 2kHz signal. But not knowing the cap value makes determining that all the harder.
I will be going home in a few days. After that it's up to my cousin to build or test with some sort of circuit.
AnalogKid
Joined Aug 1, 2013
12,295
My cousin thinks ( I disagree ) the cap and resistors should generate a 2kHz signal. /QUOTE]
Actually, the R and C form a lowpass filter that works *against* passing a high frequency signal. That's one of the reasons I thought the input signal probably was driving the transistor as an on/off power switch to the beeper. The beeper part number changes that.
If the schematic is correct, the circuit cannot be an oscillator.
ak
28,576
IN ADDITION to what AK tells us, given that the image in post #7 shows a symmetrical mounting and no polarity mark, and that the device has a bypass resistor, it probably does not hold any polarity sensitive elements such as transistors. Probably that cap on the transistor base is to smooth a square wave to improve the sound from that piezo transducer. It might even be that the intention is just to deliver an audible "click" when other buttons are pressed on the panel. I have come across that at least once.
