Help me figure out if this is capacitive or inductive pick up
AF_Maxwell
Joined Dec 12, 2018
36
I'm placing my oscilloscope probe tip over a singled end of a CAN bus line with a little meander shaped bodge wire at the end.
I expected to read spikes with inductive pick up but I'm getting square waves. I thought maybe I was capacitively coupled so I tried to change the orientation and the signal falls away like I would expect from inductive pick up.
If I am really doing inductive pick up I am confused why I'm getting a square wave, will an oscilloscope probe act as a passive integrator. Even so I would not expect it to be such a perfect square. Shape works if it's capacitively coupled though...
What do you think, I need to know if the oscilloscope probe lead is causing this and why but I don't know how to figure this out.
Scope is Tenma 72-8710A with its standard probe.
AF_Maxwell
Joined Dec 12, 2018
36
True it's both. To answer my own question capacitive coupling is dominating the signal I'm reading.
Wasn't really worth asking sorry.
Always worth asking a good question. With this sort of thing it's better to look at it using a fields in space prospective. The circuit theory intuition of discrete components fails to provide a good path to learning here.
28,225
What you will see with an open probe on a high gain scope channel may not be at all what is expected. A portion of that result often comes from capacitive coupling to a signal that is not expected. What is important is to always verify that what you see is actually what you are attempting to see. And not claiming a new discovery until you have verified it.
