Still think you should add a 10Ω resistor in series with the push-button.Final (?) update.
Yes, it may not be a problem, but there is the makings of a small spot-wielder there.I've never seen a problem with the switch contacts in similar circuits, but this one does have a relatively large decouple cap.
The LEDs that I use can handle a 9 volt battery without a resistor, does that mean that I could skip all resistors including the ULN2804?I've never seen a problem with the switch contacts in similar circuits, but this one does have a relatively large decouple cap. 100 ohms would limit the peak current to 90 mA.
Probably not.The LEDs that I use can handle a 9 volt battery without a resistor, does that mean that I could skip all resistors including the ULN2804?
So the CD4017 will basically act as a resistor, and need resistors in order to not damage itself if the voltage/current/mA from the power source is heigh enough?Probably not.
The issue is the current needed by the LED for acceptable brightness. At 10 V, a CD4017 output is rated to source 2.6 mA (typical). Even for a "high brightness" LED, that's not much. If your part has internal current limiting that is fixed at a higher value, it can damage the chip.
What is your LED part number / vendor / web page?
The circuit can not work as shown.What will happen if I connect like this? Will it harm the 4017? I connected the GROUND (-) entry to the CLOCK (14), what’s the pros/cons with that? If the 4017 won’t work, are there any other alternative that could replace it and work without any resistors?
A requirement in post #1 is that all LEDs are off when the switch is open.This circuit is like post #20 but without using Q0 and 2N4403.
I want the light to shine bright. My LED’s are basically small incandescent lamps, they shine just fine when I’m using a 9 volt battery but with anything smaller than that they start to vague.The circuit can not work as shown.
You have no power or GND connections to the chip.
Leave pin 12 floating.
You are driving both the true and inverted clock inputs with the same signal. This will not work reliably.
It is not clear which polarity clock signal you intend to use. Whichever one it is, it needs a boas resistor and a debounce capacitor
There are other devices that can achieve the same result, such as a shift register (which is what a Johnson counter is internally), but the extra steering logic makes it a significantly more complex circuit.
What is your aversion to having a current-limiting resistor?
No, they are not.My LED’s are basically small incandescent lamps,
