Hello!
I'm working on making a battery solution for a device which doesn't support it by default. I'm replacing the original outlet+adapter configuration with a single battery with a cable.
I'm pretty sure I've got the right battery and the right voltage regulator.
However, I'm not entirely sure how to solder this together!
What I wonder is; Will this work? (See image)
Which means, solder it together in the areas marked green, and the same with the little plug on the right.
Thanks in advance
Thanks in advance
