My teacher said that it is still positivi but I don't know why.The equivalent resistance will be negative resistance.
But here you are using CCVS. So the situation will be different.Real example here is how it would look like for positiv current :
Which I see that it is equivalent to positive resistance. But this one ?
I don't know. Because I can't change how the controlled source is "picking up" the current. So for him it will be - I_E.
I'm sorry I may not understand this one.
I expected that this rule I learned is works for both of them.First, you showed us the circuit that contains VCCS. And now your second circuit contains CCVS. And you expect them to behave the same?
But the first one the voltage the VCCS is picking like that :
Hi,Hello !
I've got one question about controlled source.
When I have this situation :
I heard that there is a rule when I want to change controlled source into resistance or conductance. And it looked something like that.
I don't know if I get it because I don't see te circuit and how it works but looking at this :Hi,
I dont know if you want to think about this in more general terms or not, but the way you have that connected it is kind of simple.
If you have a dependent current source that is controlled by a voltage that is actually across the source, then we can write:
R=v/I(v)
where R is the proposed resistance and v is the voltage across it and I(v) is the current source dependent on the voltage v.
Now since the current source I(v) is related to the voltage usually by a constant factor, we can say that the current source is:
I(v)=a*v
or anything like that.
Substituting that into the first equation we get:
R=v/(a*v) which of course is R=1/a
so we can see that if a=4 then the resistance R is 1/4 for example.
If the dependent current source is more complicated then it wont work out so simple.
If I(v)=a*v^2+b*v+c then we end up with:
R=v/(a*v^2+b*v+c)
which can not be reduced to a single resistance unless of course the voltage v is constant, which would not make sense although i guess it is a possibility in a static circuit.
Hello again,I don't know if I get it because I don't see te circuit and how it works but looking at this :
which is the same like this circuit :
The simulations says the same :
https://tinyurl.com/25etxrtm
So I thought that no matter what is the voltage "U". Even if it's U = -Ur the controlled source can be changed into positive resistance.
EDIT:
For example here :
So which one of this (bUr or Ur) is negative to get negative conductance
