Hi E,hi C,
Post images of your IDE settings as per the Options menu, we can then suggest changes.
E
Hi E,Thats no good.
Click on the Option eg: UART
Hi E,How long does the program I posted yesterday take to run from the first Break to the second Break.??
The first Break shows approx 1800uSec, then use Ultimate to restart the Sim
the second Break shows approx 501,800uSec , in a 5 minute run.
Hi E,How do you know it did not change to '1'
You don't have the 'Basic Tracking' selected.???
Hi E,Where and how are you seeing a '1'??
Hi E,hi C
If you have all those views switched On it will run slow.!
Only use them when needed.
E
Hi E,hi,
If you intend calling get_msg at a 0.5Sec interval, where the get_msg data may require a time longer than 0.5S to acquire, you should Disable the TMR1 interrupt.
Then Reload TMR1 and Re-Enable the Interrupt.
Consider having the get_msg outside of the interrupt routine, test for Int_cnt > 7 outside the Int subr.
E
Hi P,Does this run better than Proteus. I’ve been finding that Proteus’s animated LED causes counters and uC to slow down to failure.
Hi W,The personal license for full software with all the bells and whistles are quite the deal! It's very different from the Proteus sim... lots of good stuff, will take some time to learn it.
