Hi ,I am studying about Filter Circuits and I cannot find " How to control (adjust) the gain in active low pass filter circuits? " could you explain me ? thank you .
All simulated resistors have a current direction polarity, which gives a plus or minus sign when viewing the current in the resistor.I use proteus and there is no polarized resistor in there
You do realize that adjusting the gain of the Sallen-Key filter, also affects the filter frequency response for a given set of filter component values(?).How to control (adjust) the gain in active low pass filter circuits?
Changing the gain of a Sallen-Key filter actually changes the pole locations and alters the filter type, changing the group delay and passband ripple. If you want to change the gain of the filter, you can add an adjustable gain stage to the output. In this way the gain setting and the filter characteristics are decoupled from each other. This is the easiest way to do what you seem to want to do.You do realize that adjusting the gain of the Sallen-Key filter, also affects the filter frequency response for a given set of filter component values(?).
