How can we control Low pass filter.
apollo321j
Joined Dec 30, 2020
28
Hi ,I am studying about Filter Circuits and I cannot find " How to control (adjust) the gain in active low pass filter circuits? " could you explain me ? thank you .
ericgibbs
Joined Jan 29, 2010
21,544
hi 321,
As you mention Gain, I assume that a OPA is going to be used as part of the LP filter.??
Do you have a staring point circuit diagram and a LP filter specification.?
E
ericgibbs
Joined Jan 29, 2010
21,544
hi 321,
That looks OK for a test run.
What frequency ranges did you have in mind, we should have a design spec.
eg: the frequency point at -3dB and Gain figure.
E
ericgibbs
Joined Jan 29, 2010
21,544
hi 321,
Will look over your posted circuit shortly.
As a LP filter, this demo plot is what I would expect to see.
It has a Low Pass bandwidth from 1 thru ~20kHz the -3dB point on the plot
E
Added the actual circuit.
ericgibbs
Joined Jan 29, 2010
21,544
hi 321,
This is your post #3 circuit, with the damping resistors at [R1/R2]~0.6 giving ~+4db 1 Hz thru #20kHz
Do you have values for the circuit in post #6.?
E
apollo321j
Joined Dec 30, 2020
28
oh . I am so sorry I write them but pc gived me error then delete them Voltage = 10 Volt, R0= R1 = 1K OHM , Capacitors = 1pikoFarad,R3=5.85 KOHM,R2=10K Ohm .Then , I think I find wrong bode plot my transfer function absurd but I don't know (My transfer function = 1.585/(s^2 + 0.002415 s +1).my question " Design second order active low pass filter with 4 dB gain. Determine cut-off frequency (you are free) and use appropriate circuit elements. Compare the results with the desired paramaters. (cut-off) "
ericgibbs
Joined Jan 29, 2010
21,544
hi,
This is your circuit in post #6.
What -3dB point design point did you calculate.??
E
Update:
Check your 1pF value calculation
ericgibbs
Joined Jan 29, 2010
21,544
hi,
I guess you know that you should expect a gain of ~+4dB from that type of circuit.
The 5.85k/10k are important.
There are ready calculated Tables for these values.
BTW: Note C2....
E
apollo321j
Joined Dec 30, 2020
28
No ,I mailed to my teacher he said okey he accept my submission thank you for all helping me ericgibbs.Have a nice day I solve it .
ericgibbs
Joined Jan 29, 2010
21,544
hi 747,
In simulators the current direction in components is specified due to the Net list, so some indication of polarity can avoid mistakes in measuring the current direction in a component.
E
@anniel747
Added example.
R2 has been rotated 180 deg
E
R1 N001 0 1k
R2 0 N001 1k
V1 N001 0 10v
.tran 1
.backanno
.end
38,718
I use proteus and there is no polarized resistor in there
All simulated resistors have a current direction polarity, which gives a plus or minus sign when viewing the current in the resistor.
This current polarity direction normally doesn't show on the simulation schematic.
Papabravo
Joined Feb 24, 2006
22,116
You do realize that adjusting the gain of the Sallen-Key filter, also affects the filter frequency response for a given set of filter component values(?).
Changing the gain of a Sallen-Key filter actually changes the pole locations and alters the filter type, changing the group delay and passband ripple. If you want to change the gain of the filter, you can add an adjustable gain stage to the output. In this way the gain setting and the filter characteristics are decoupled from each other. This is the easiest way to do what you seem to want to do.
