How can three currents leave a node with no current flowing in??
Mojo Pin__
Joined Apr 13, 2019
83
I thought KCL was "everything in equals everything out" or "the sum of all currents entering and leaving a node equals zero".
When we were doing this example in our lecture today the professor showed this slide:
But to me this looks like the node with id and iout leaving it doesn't have current going in to it, or does it?
I thought what he was trying to say was something like this:
But it just doesn't make sense to me,
Any explanaition would be greatly appreciated
neonstrobe
Joined May 15, 2009
200
Since all resistors in the equivalent circuit are in parallel, and the current source is pulling current down, the voltage on the output node will be negative. So Vout is negative. You can then work out all of the other currents. If the result is negative to the direction shown it means current actually flows in the other direction.
Mojo Pin__
Joined Apr 13, 2019
83
i see what you mean, thanks for the explanaition!
Mojo Pin__
Joined Apr 13, 2019
83
Another way to think about it: Arrows (vectors) show which direction is defined as positive. A negative (scalar) value indicates flow in the other direction.
yes, nice one, but if all arrows pointing out of the node are defining them as positive that makes it confusing again. But... the AC signal part is the Vector and the DC part is the Scalar? Am i understanding you here?
dl324
Joined Mar 30, 2015
18,490
If you're familiar with the circuit, you can assign proper directions for the currents. Otherwise, you guess and sometimes you guess wrong. If you assign all currents as leaving a node, you're not even trying to guess and at least one current direction is wrong.
wayneh
Joined Sep 9, 2010
18,180
No confusion, it just requires at least one to have a negative value.
No, I don't (can't?) think in AC and my comments are limited to the DC world.
Mojo Pin__
Joined Apr 13, 2019
83
that's why I was confused initially, I see what you are saying, I just don't understand why the professor chooses to make them all leave the node if that's impossible.
I think it is because he has chosen to make the voltage drop in a certain direction such that the current would have to be flowing in a corresponding direction. So in terms of how it is drawn the fact that the voltage drop would be negative means that 2 of those currents would be negative despite the arrows leaving the node.
Does that sound like a good explanation?
dl324
Joined Mar 30, 2015
18,490
If I give him the benefit of the doubt, he knew that one or more of the directions he assigned were "wrong" and wanted you to be able to handle a wrong direction assumption that you might make in the future.
A wrong direction assignment will give you a negative number for the current. It all works out in the end.
