I have this piece of code which allows to sample at 1 msps (1 Mhz) and it works on arduino due but instead of transferring to serial port I want to put into declared array using DMA. I want it to take 4000 samples every 1 us. How can I do this.
this is the array I want to declare
int myArray[4000];
and here is the code.
#undef HID_ENABLED
// Arduino Due ADC->DMA->USB 1MSPS
// by stimmer
// from http://forum.arduino.cc/index.php?topic=137635.msg1136315#msg1136315
// Input: Analog in A0
// Output: Raw stream of uint16_t in range 0-4095 on Native USB Serial/ACM
// on linux, to stop the OS cooking your data:
// stty -F /dev/ttyACM0 raw -iexten -echo -echoe -echok -echoctl -echoke -onlcr
volatile int bufn,obufn;
uint16_t buf[4][256]; // 4 buffers of 256 readings
void ADC_Handler(){ // move DMA pointers to next buffer
int f=ADC->ADC_ISR;
if (f&(1<<27)){
bufn=(bufn+1)&3;
ADC->ADC_RNPR=(uint32_t)buf[bufn];
ADC->ADC_RNCR=256;
void setup(){
SerialUSB.begin(0);
while(!SerialUSB);
pmc_enable_periph_clk(ID_ADC);
adc_init(ADC, SystemCoreClock, ADC_FREQ_MAX, ADC_STARTUP_FAST);
ADC->ADC_MR |=0x80; // free running
ADC->ADC_CHER=0x80;
NVIC_EnableIRQ(ADC_IRQn);
ADC->ADC_IDR=~(1<<27);
ADC->ADC_IER=1<<27;
ADC->ADC_RPR=(uint32_t)buf[0]; // DMA buffer
ADC->ADC_RCR=256;
ADC->ADC_RNPR=(uint32_t)buf[1]; // next DMA buffer
ADC->ADC_RNCR=256;
bufn=obufn=1;
ADC->ADC_PTCR=1;
ADC->ADC_CR=2;
void loop(){
while(obufn==bufn); // wait for buffer to be full
SerialUSB.write((uint8_t *)buf[obufn],512); // send it - 512 bytes = 256 uint16_t
obufn=(obufn+1)&3;
int myArray[4000];
#undef HID_ENABLED
// by stimmer
int f=ADC->ADC_ISR;
if (f&(1<<27)){
bufn=(bufn+1)&3;
ADC->ADC_RNCR=256;
void setup(){
SerialUSB.begin(0);
while(!SerialUSB);
ADC->ADC_CHER=0x80;
ADC->ADC_IER=1<<27;
ADC->ADC_RCR=256;
ADC->ADC_RNCR=256;
bufn=obufn=1;
ADC->ADC_PTCR=1;
ADC->ADC_CR=2;
void loop(){
obufn=(obufn+1)&3;
