Data Transfer Timing in I2C
MTech1
Joined Feb 15, 2023
181
In I2C communication, the Master sends data to the Slave and receives data from it. This communication occurs over clock edges, specifically the rising and falling edges. In the setup with pull-up resistors, it appears that the Master transfers data to the Slave at the falling dge and receives data from it at the rising edge
I want to clarify: during which clock edge does the Master transfer data to the Slave and receive data from it?"
Ian0
Joined Aug 7, 2020
13,298
It is level driven, not edge driven. Data is only allowed to change when the clock is low. Data, therefore, must be stable all the time the clock is high.
