Of course I do. But you're in very good hands and there's too many cooks in the kitchen.hahacool!
but wait. do you know how to fix the problem with my circuit? i mean. without that monster thing.............
thnks!
R1 is probably the resistance of the wire in the transformer. Do not play with that. It just makes heat.R1 from 0.2 ohms to 200 ohms.
1) Change the value of D5 to change the output voltage. Vout2 is VD5-0.7V. Do you know why?
2) You change the value of Vout by changing the turn ratio of L1:L2.
You need some voltage across Q1C-E. (example: Vout has ripple in the 55 to 65V range, then Vout2 could be 50V) This way the lowest point of Vout is above Vout2 by a little.
If Vout is very large and Vout2 is low then you have too much voltage across Q1 and heat is (voltage across Q1 X current out).
School: How do you lower the voltage at Vout? Hint 400m/25m is not the turn ration.
Ask questions.
People here are the best and very eager to help.Of course I do. But you're in very good hands and there's too many cooks in the kitchen.![]()
.| Thread starter | Similar threads | Forum | Replies | Date |
Calculating the ripple current for a capacitor in a vfd | Power Electronics | 6 | |
| G | Reduce number of batteries from a school practical circuit | Analog & Mixed-Signal Design | 34 | |
| Y | logic of L_critical and L_ripple in buck converter | PCB Layout , EDA & Simulations | 0 |
