how can i make temperature constant amplifier with bjts?
songhan
Joined Jun 8, 2021
19
If you start with a BJT with a current gain of 100 and make the gain of the circuit itself 10, then the gain will be 'fairly' constant even with temperature even though the Beta of the transistor changes with temperature. In this case the gain of 10 is sometimes referred to as the 'forced" gain.
You also have the issue of base emitter diode drop which also changes with temperature and that could cause the bias point to drift and thus the output offset. The output offset is more important in DC amplifiers but you did not specify AC or DC for your circuit yet.
Keeping the gain low (for each stage) and providing negative feedback might get you there but it depends how good you need it to be. For exceptionally good stability you probably want to go with a differential amplifier which has some degree of automatic compensation for drift.
i dont think i need that much good precision of stability, i just wanted to know about normal ways that we use to compensate the temperature effect. I just learned bjt parts of electric circuit class and i wonder that is there any way that i can compensate temperature effect of bjt amplifier. Because there is nothing about compensating temperature effect of bjt circuits in the book.
Ian0
Joined Aug 7, 2020
13,306
Try this: The two transistors whose part numbers overlap are BCM857C.
The open-loop gain will reduce by about 50% at -55°C according to NXP's datasheets, but that should make precious little difference to the overall amplifier.
songhan
Joined Jun 8, 2021
19
Collector of Q5
Ok thanks since you gave me example, i will try to understand how it works. it's my project i will just refer your work. i should study more how your circuit works.. I don't understand how your circuit works.
Anyway thanks for your help! it helped a lot :)
Ian0
Joined Aug 7, 2020
13,306
Ian0,
This is homework help.
Bob
Thanks for the reminder! It's a stock circuit (the innards of an op-amp) and we've already said "op-amp". The challenge now is to explain how it works, and why the gain remains stable over temperature!
I'd recommend any of the texts on audio design such as Douglas Self and J. Linsley-Hood.
atferrari
Joined Jan 6, 2004
5,031
The OP seems to be revealing the required specs (creating them??) as the thread progresses.
Why not to transcribe verbatim the description of what he intends to do?
Starting with the inconsistent title.
Constant temperature? In outer space, maybe and I think, for not so long.
Audioguru again
Joined Oct 21, 2019
6,826
You must learn about transistors to understand how the circuit works.
It has a gain of 1 like a piece of wire and an output resistance that is fairly high.
Why didn't your teacher teach you about transistors??
songhan
Joined Jun 8, 2021
19
technically he teached it. But the problem is he taught only basics about bjts and gave such burdensome project like this...
Ian0
Joined Aug 7, 2020
13,306
I suggest that you read John Linsley-Hood The Art of Linear Electronics ISBN 0 7506 0868 4 which has less of the transistor theory, and more of the circuit theory. There is a very good section on design of amplifiers using bipolar transistors.
My circuit came out of one of his other books John Linsley-Hood Valve and Transistor Audio Amplifiers ISBN 0 7506 3356 5.
Now you can make a turntable preamp that will work down to temperatures where the grease in the turntable bearings has set completely solid, and the stylus compliance has gone completely stiff, and up to temperatures where the vinyl starts to melt!
DickCappels
Joined Aug 21, 2008
10,661
Emphasis added.
Please be gentle.
In my first electronics class all we learned about were vacuum tubes. Now I am dating myself.
Audioguru again
Joined Oct 21, 2019
6,826
I think some old teachers are still teaching about the 53 years old 741 opamp because they never learned about newer and better opamps.
Learning and teaching are different now because of the internet. Now the teachers send the students here.
MrAl
Joined Jun 17, 2014
13,858
Emphasis added.
Please be gentle.
So then i guess you didnt have sex ed back then either ? (ha ha just kidding "dating myself" har har) :)
Oh wait, then maybe you did :)
I have to agree with AG with the 741 i dont like that op amp either anymore. Back in the day maybe, but that one is really outdated except in cases where you have to repair something that has one in it.
