How can I have a high-current buffer for the op-amp in Howland current source?
Tran Binh Duong
Joined Aug 1, 2016
1
You can do it, in principle, with a Howland current pump. However, you will need an op amp that can put out ±150mA and ±15V at up to 100kHz. This might require a combination of an op amp and a high-current buffer, and a heat sink.
Dear Ron,
I mean that I need a bipolar buffer placed at the output of op-amp.
PS: I want to make a AC Current Source based on Howland Current Source which be able to put out 1A and ±15V at up to 50Hz-10kHz.
Mod note:
Please don't hijack other member's thread, now you have your own.
Our Fanatic member Ron H had not join the forum about 6 months, he may not answer your question, I will also left a link to there on the thread that you posted, if you have any question then you just post on your thread, thank you.
This thread was split from -- AC constant current source.
12,241
Are the 1 A and +/-15 V requirements RMS or peak values?
Is one end of the load connected to the system ground?
What is the amplitude of the signal source?
