Horizontal Boring and Milling machine AFD 100
Fablin
Joined Jul 30, 2020
Hello, recently I've had contact with the Romanian Horizontal Boring and Milling machine AFD 100 made in Bacau in 1985. and I've been wondering if someone had worked with this kind of machine before because we want to repair it and we're missing the control panel wiring diagram. If someone still has an electrical sheet or something similar related to this machine I would be very grateful. Thanks!:D
( I apologize for any typos or bad English)
Fablin
Joined Jul 30, 2020
So is this ran just by relay logic or some kind of CNC controller?
From the pic's it just looks like non-CNC?
Max.
That's right, relay logic only, it's not a CNC, just old Romanian relay logic
I don't know much about it either I just hope someone has the control panel wiring diagram :D
Alin.
MaxHeadRoom
Joined Jul 18, 2013
30,836
It is probably going to be close to a miracle to obtain DWG's from some of those old machines.
Have you tried any of the machining forums?
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,836
I have worked in the machine tool repair and maintenance since before that date, and have never come across that make of M/C, I suspect they could be rare in N.A.
I assume that manuf. is no longer around?
If you have one particular issue, with no prints, it is usually a case of circuit tracing in the area of the fault, Document as you go! ;)
Max.
Fablin
Joined Jul 30, 2020
Thanks, everyone!
I appreciate the help, I will try that forum too.
Hope you all have a nice day and stay safe! :)
Alin.
Romudel
Joined Feb 1, 2022
Hello.
I´ve been working on that schemes (AFD100, 1981) and i made some notes.20220201_110712.jpg20220201_110740.jpg
it is not complete but could be help. If you want i send you.
