I have a Horizon 7.0AT treadmill with a dead console that someone was giving away for free on Facebook Marketplace. They had recently had it moved from the basement to a finished part of their garage only to find it was no longer working. I figured for the price I'd take a shot at fixing it myself.
I tested the cable between the lower and upper board first since that seems to be a common fault point after a move but it checked out. So possibly it was plugged into to an outlet that wasn't properly grounded once moved and subsequently suffered some sort of surge through the upper board?
The upper board receives power that's distributed to parts of it, but other parts are completely dead. It shows no sign of life - no lights, no working buttons. There also doesn't appear to be any schematic available online. There's a 7 blink code on the lower board that, as far as can tell, is a communication error with the upper board, which is probably not taking back at all in its current state.
Here's a picture of it when I first opened up the console, a picture of the top of the board after I did a crappy job swapping out a few suspicious capacitors, and a picture of the bottom of the board. Also a PDF from Johnson Fitness on the lower board that contains the pin layout to the upper. Any help would be greatly appreciated. Thanks.
