Exactly: that's the question I was encouraging the TS to answer for himself. Transformers, even audio transformers with extended low-frequency bandwidth are relatively efficent.I see nothing that makes a transformer-coupled amplifier less efficient than a direct-coupled amplifier except the tiny amount of heating in the resistances of the transformers that wastes a small amount of power.
I guess old teachers make assignments for severely distorted old acid rock amplifiers, not for modern hifi amplifiers.And I also forgot that the original spec was for Class B!
What a coincidence. My first job was as a technician on the Philips car radios production line. The latest one used AD161 and AD162 germanium complementary output transistors. It was spec'd at 4W into 8 ohms so instead of using bridged amplifiers, it used little output transformers to step-up the output signal voltage.Probably he meant to specify AD161/AD162
Hi Eric,hi a,
Please post your transformer amp LTS asc file.
E
Yes, but i think it is intend to get a crossover distorted signal in output, as it is class-B.Hi a
Checked your Fi5, severe cross over distortion, try a 0.68v input signal ie: 10%.
E
Homework Help | Feedback and Suggestions | 12 | ||
Y | NEED HELP TO MY HOMEWORK | Homework Help | 2 | |
G | Homework Help design a combinational circuit | Homework Help | 14 | |
Logism Circuit Design Help. HEX Display | Homework Help | 7 | ||
M | Design homework need help BJT Please Help | Homework Help | 4 |
