Congrats and welcome to AAC!I built this 16 digit calculator using RGB 7 segment LED displays.
You can avoid that problem in the future by putting the chip in a machined pin socket.I removed and reseated it so many times, that I wore out the pins on the first one and had to toss it.
Not for this project. Part of the fun has been changing the design and adding new functionality. I changed the input from a 74922 with a 4 x 4 keypad, to a standard PS/2 keypad. I also added a serial EEPROM for non-volatile storage. I tried to connect an old SP0256 speech synthesizer chip, but it seems to be fried. I do want to learn to make PCBs, but I need to start with something smaller.Are you planning to make a PCB?
I have had problems like that, and debugging was an adventure! Notice the chip at the bottom labeled "Stop Latch" - this was only used for debugging, and would stop the clock on a certain opcode, letting me observe the state of all the registers, and hopefully discover something. I would re-burn the program over and over, as I narrowed down the problem. Some of those breadboard jumpers are rather low-quality, and don't survive many bending cycles. I'd find a loose broken wire, with the stripped part still in the hole. But as long as I don't fiddle around with the design, it keeps working OK.I found an error. There is one orange jumper there that has fallen out of its hole.![]()
If you bought the same jumpers as me, made at Coronaland, the reason is simple: their terminals are round. They do not have the expected square section.I have had problems like that, and debugging was an adventure! Notice the chip at the bottom labeled "Stop Latch" - this was only used for debugging, and would stop the clock on a certain opcode, letting me observe the state of all the registers, and hopefully discover something. I would re-burn the program over and over, as I narrowed down the problem. Some of those breadboard jumpers are rather low-quality, and don't survive many bending cycles. I'd find a loose broken wire, with the stripped part still in the hole. But as long as I don't fiddle around with the design, it keeps working OK.
Yup. I bought a whole bunch too. They keep getting shorter and shorter as I re-strip them after they break.That is why they insert so easily and fail so frequently. I realized that too late after happily buying to big bunchs of them.
I buy those from Ali Express and the only problem I've had is that 1 (out of 600) was missing a hood. No breakage yet, but I've only used a couple hundred of them.Yup. I bought a whole bunch too. They keep getting shorter and shorter as I re-strip them after they break.
