Home Work logic gate
WBahn
Joined Mar 31, 2012
32,823
MOD NOTE: Moved to Homework Help
You are just throwing your homework up asking people to do it for you.
That's not how it works.
YOU need to post YOUR best attempt to work YOUR homework. We will then try to help you see where you are going wrong and guide you a back to a good path. We will NOT do your homework for you.
Also, be aware that you are using very non-standard descriptions and notation. You will probably need to spend some time helping use figure out what you mean in terms that we can understand.
Behrooz14255
Joined Dec 15, 2020
11
I worked hard during the week
I searched a lot
But i can not to result
WBahn
Joined Mar 31, 2012
32,823
You need to define what the terms are in your tables. Most of us are going to be unfamiliar with them, particularly without some context.
It seems like you are working with multi-level logic. Is that the case? If so, then you are going to have to be even more explicit is defining everything as most of us have never worked with that type of logic, though there are plenty of people that will be able to get far enough quickly to be able to help you.
You have both ternary and quaternary gates defined. What type of logic are you using?
Behrooz14255
Joined Dec 15, 2020
11
Multiple Value Logic (MLV) ternery gate 0 1 2
