Hole drilling problem
RBR1317
Joined Nov 13, 2010
715
"...is designed to have seven speeds."
"...determine the six spindle speeds..."
So have you determined whether to find the 6 or 7 speeds?
LesJones
Joined Jan 8, 2017
4,544
Start by working out the minimum and maximum speeds required. Post your result and we will tell you if you calculated those two values correctly.
Les.
Picbuster
Joined Dec 2, 2013
1,062
Hey Jonas,
did you end up finding the answers to these questions? i have been given the exact same ones, they are difficult!
Mod note: created your own Thread.E
Link to old:
https://forum.allaboutcircuits.com/threads/try-to-solve-this-problem.153838/post-1322583
A drill will cut x mm per rotation this will produce the max speed to move into the material.
However; type of material will consume power so the cutting edge will produce heat.
Now you have to look into the table from the drill manufacturer to find the max speed in relation to the material.
This will produce meters per minute. The diameter allows you to calculate rotation per minute.
Now you are able to calculate the allowable speeds ( two values: refs per minute and max speed to move into the material.)
The same will apply for milling in x,y and z axis.
That's all.
Picbuster
