Hold value of counter at terminal count
nekojita
Joined Nov 19, 2010
170
In the photo below showing a a 4 bit counter output and in the attached file is the 4 bit counter. The LTSPICE simulation works as expected as shown in the simulation.
What I need however is when Q3 or possibly Q4 output goes high, a latched output goes high and stays high until reset. Currently, it rolls over on the next clock cycle.
How can I modify the 4 bit counter circuit to stop in the state of the terminal count?
Thanks,
Neko
AnalogKid
Joined Aug 1, 2013
12,268
That is what his circuit does - when the third output goes high, the circuit freezes until reset. As the dotted line indicates, you can move the sense line to the 4th output and the circuit will freeze on count 9.
ak
Danko
Joined Nov 22, 2017
2,236
Hi Neko,
I just noticed something odd. In your sim pic, the count ends on the fifth clock cycle:
Yes, it is.
Remove "startup" from .tran directive in downloaded file.
It should be stop on the front of fourth high clock pulse.
nekojita
Joined Nov 19, 2010
170
ak
Hi ak,
Sure, I see that. Both Danko and I used the 3rd clock output. Using the circuit that he posted, his circuit for the Q3 output freezes on the fifth leading clock edge. When I run his sim, the Q3 output freezes on the fourth leading clock edge.
I can't reconcile the difference since it the same circuit. Can you explain the difference?
Thanks,
Neko
nekojita
Joined Nov 19, 2010
170
I think the vertical line at 0ms is not a true rising edge. The simulation starts with the clock high.
Hi Chris,
So two things, the pulse profile has no delay meaning the that the first clock rising edge happens at t=0:
As I suggested earlier, I am running the file that was posted that shows the frozen terminal count on the 4th positive clock:
So, what's up?
Neko
nekojita
Joined Nov 19, 2010
170
Hi Neko,
Yes, it is.
Removing startup didn't change anything; terminal count still goes high and stays high after 4 positive clock pulses. -Neko
nekojita
Joined Nov 19, 2010
170
Hi Chris,
So, what's up?
Neko
If I delay the clock by half a period, i.e., 16.66ms, the output goes terminal and locks after 4 positive clock cycles.:
Comments?
Neko
nekojita
Joined Nov 19, 2010
170
Hi Neko,
Yes, it is.
Hi Danko,
My sim results show that terminal output stops on the front of fourth high clock pulse regardless of whether startup is in the .tran directive or not. I'm confused?? Why it happened on the fifth cycle in your sim but not mine?
Comments?
-Neko
