Hold push button, timer, then activate relay.
IntempoDK
Joined Dec 29, 2016
9
It won't work. You have the timer configured as a one shot that will trigger as soon as the button is pressed. That will toggle the flip flop as soon as the button is pressed.
You have to let the timer time out and add some logic to implement your 5 second button hold requirement. Once you do that, you'll have more components than the last solution offered.
Can you write me a list of what to purchase for it?
Half of the items on his diagram im not even sure what is :D
If possible, even a diagram like the one i made, its ALOT easier for me to find round in that.
38,842
but the simpler the better in this case, i have to be able to make it too
If i can do it without the 4027B then its even better, if any can look at this and tell me if its going to work or not
It won't work as shown, as dl324 noted.
You need a toggle flip-flop, such as the 4013, for you circuit.
A flip-flop latch, such as a 555 configured for that, won't readily do what you want.
As far as simple, the circuit I posted in post#15 has fewer parts than yours (requiring only one IC).
You can substitute a BJT (bipolar transistor) for the MOSFET to drive the relay if you like, as shown here.
IntempoDK
Joined Dec 29, 2016
9
You can substitute a BJT (bipolar transistor) for the MOSFET to drive the relay if you like as shown here.
Thanks, but im having a bit of a bind finding around in our diagram, im used to the ones like i posted, looks like you have a simulation cirquit, and where does push button come in? the hold relay where i attach the inverter and so on, maybe a diagram a bit like the one i made below, that one i can read :D ?
38,842
I simplified the circuit by removing the simulation stuff, so it should be easier to understand.
You can get the pinouts for the CD4013, including power and ground, from its data sheet here.
The two flip-flops shown (U1 and U2) are actually in one CD4013 package.
SET is the same as PRE and CLEAR is the same as CLR.
I know reading schematics can be a little confusing to the newbie but after a little practice it should become easier.
Normally the signal flow is from left to right, with the power going from top to bottom.
The triangle symbol indicates circuit common.
Be sure and double-check the circuit after you build it.
Most circuit problems are due to wiring errors and/or using the wrong pinout for a part.
I use a highlighter pen to mark off each connection on the schematic as I do a continuity check on the circuit.
Any further questions you have on all this or if you need help with the parts, let us know.
IntempoDK
Joined Dec 29, 2016
9
Thanks, this is greatly appreciated :)
I will order the components and see if it works out :)
Tonyr1084
Joined Sep 24, 2015
9,744
Crutschow: If you drive the preset high (U2) and it drives Q high, how are you resetting Q back to low? Does driving preset and reset high at the same time result in Q and /Q going high so that when preset goes low Q goes low again?
IntempoDK
Joined Dec 29, 2016
9
The CD4013B, the only one i can find any my supplier here is `
Logik IC - Flip-Flop Texas Instruments CD4013BE Set (standart) and reset differential DIP-14
would that be okay?
And the Eletrocondensator, 22 uF special voltage? or 50Vs good enough?
Jony130
Joined Feb 17, 2009
5,600
Yes, you are on the right track
http://forum.allaboutcircuits.com/threads/ltspice-and-cd4013.129753/#post-1065138
would that be okay?
CD4013 from Texas Instruments is what you need.
Every capacitor with voltage rearing >> 5V (1.5 times Supply voltage) is good.
38,842
Here's a variant of crutschows circuit.
As I noted previously, the problem with such a circuit is that the 4013 has a clock maximum rise and fall time requirement, as the clip from the data sheet shows below.
Thus, although it may simulate okay, the slow RC clock risetime from the input delay circuitry could be problematic in the actual circuit.
This is one case where the simulation can give erroneous (good) results since the model likely doesn't include provisions for failure if the clock risetime is too slow that the actual circuit may exhibit.
eetech00
Joined Jun 8, 2013
4,726
Good point....I'll have to rethink the input circuit..
eetech00
Joined Jun 8, 2013
4,726
Hi
Just reporting back that I bread boarded the circuit in post #32. I didn't drive a mosfet, but an LED connected from pin 2 to +5.
The circuit does work as intended. On power up, U2b Q bar is set high. When +5 is applied to the input, the LED lights up after about 5 seconds,
and shuts off when +5 is removed from the input.
As an additional test, I replaced the input circuit with a slow ramp using a function generator. Still operated as intended.
eT
38,842
Then it is operating well outside its stated limits.
But, in general, it's not good practice to build a circuit that knowingly operates outside the devices specification limits. It could come back to bite you at a latter time (for example at a different operating voltage or temperature). :eek:
dl324
Joined Mar 30, 2015
18,475
+1 for that. Manufacturers don't guarantee operation outside of their specs and parts from different lots/manufacturers may behave differently. (OP mentioned in post #16 that he wanted others to be able to build the circuit.)
Using a part outside of the guaranteed specs requires incoming testing for desired behavior. HP used to do it. It must have been more economical for them to do the screening themselves vs. paying the manufacturer for custom specs.
eetech00
Joined Jun 8, 2013
4,726
Understood...
