High voltage, High capacitance Capacitors
Discussion in 'Power Electronics' started by artmaster547, May 11, 2017.
  1. artmaster547
    Jan 6, 2016
    410
    7
    Hi All I am designing a 3.5kW Charger and trying to source a capacitor for a boost power factor correction converter I am designing. I have come into a bit of problem for the design I need a capacitor with the following properties/ratings: Vdc: 450 V and capacitance of 470uF, I believe usually metal film capacitors are used for this application. I am not bothered about space taken up I know it's going to be big, however I need this capacitor to mount onto a PCB. I was wondering if anyone knew of any capacitor that meet those ratings, or if anyone can suggest what would be a suitable solution, if I say got a load of electrolytic capacitors and then used one small metal film capacitor would that be suitable? I am very new to design so if anyone had any suggestions of what I could do would be greatly appreciated.
    Art
  2. R!f@@
    Apr 2, 2009
    9,647
    1,111
    Why metal film ?
    PFC cap is always Electrolytic.
  3. shortbus
    Sep 30, 2009
    6,653
    3,916
  4. R!f@@
    Apr 2, 2009
    9,647
    1,111
    Strange.. I never came across metalized ones in a PFC circuit in TV, A/C's or any other.
    shortbus likes this.
  5. artmaster547
    Jan 6, 2016
    410
    7
    So is it possible to just parallel up a load of capacitors that have the voltage rating, to get the capacitance I am after? Thanks
    Art
  6. R!f@@
    Apr 2, 2009
    9,647
    1,111
    How does paralleling resistors gets you capacitance ??o_O
  7. artmaster547
    Jan 6, 2016
    410
    7
    Ah! sorry I meant capacitors
  8. R!f@@
    Apr 2, 2009
    9,647
    1,111
    You can increase capacitance provided they are rated for the proper voltage.
  9. artmaster547
    Jan 6, 2016
    410
    7
    ok perfect thank you
