I don't get it.
If you are rewinding them. I like to know how you went about it.
My circuit works and I have the current limit schema, I haven't uploaded it cause it is still a rough sketch.
for ur specs u need a lower secondary voltage. The core saturates when it is overloaded and this will reduce output.
To get higher amps u can parallel the windings. I believe u are unwinding the secondary and reducing the turns to get lover voltage.
Are u using the same unwounded wires to rewind it ?
