- Joined Jan 23, 2018
- 28,602
The information on the operation is what is needed.
It seems that the 12 volt PWM signal can be applied thru a series diode the same instant that the operate command is issued, and no PWM current will flow until the 48 volt pulse ends. So there will be no need for sequential switching, the series diode will do that. That leaves the setting of the 48 volt pulse as the only thing that needs to be controlled. That can be switched off very shortly after the current peak starts to drop, which will be caused by the inductance increasing as the solenoid core moves.
