Hey everyone, this seems like a great community and I'm hoping to get a bit of help with something.
Full disclosure, I'm getting back into electronics after not really doing anything major for almost 10 years.
So I'm building a very basic prop for a friend - a lightsaber. It's nothing fancy - just needs to basically light up when you switch it on. The tricky part is all the electronics need to fit into tube that's about 1-1/4" diameter and 12" long.
I'm using a high power LED for the light source - red 2.6V @ 700mA. To power this, I settled on an 18650 battery due to the higher voltage, decent capacity and it -just- fits in a clip inside the hilt. Bonus: it can be re-charged so it saves money on that front. I would have used a 9v, but it was a little too big.
Initially I planned to just hook up a couple resistors in parallel as an interim solution as well as a heatsink on the LED and then place an order for a micro driver. The saber won't be on for long periods of time - likely turned on for photos then off (maybe 30-60 seconds at a time). However, I've been wondering about using a regulator. My local store has a few adjustable step-up/down ones that are small enough they would fit. I've just never used one before, so I'm not certain how to hook them up. They have a Ground, Shutdown, Input and Output. I get Input goes to +Battery, output goes to +Led, then Ground goes to -Battery along with -Led?
I need to get this done in about a week and I live in Canada so a lot of US supply stores (LED Supply, etc) are going to take too long to ship or be ludicrously expensive. I have a really well stocked local store.
Thanks in advance for any help!
