High Frequency Variable Resistor
Firenze02
Joined Sep 1, 2018
47
I'm looking for a variable resistor (rheostat) able to operate also with high frequency current. In particular, for my application, the current is sinusoidal with f=100kHz and amplitude of 40A.
The range of variable resistance should be 0-200 Ohm and 0-10 kOhm (obviously for higher value of resistance the current won't be 40A ).
Can you suggest some device that I could buy?
Thank you.
Alec_t
Joined Sep 17, 2013
15,171
So you want two rheostats?
It isn't obvious.
What will be the current at the 200 Ohm setting?
What will be the current at the 10k Ohm setting?
What is your budget? (High current rheostats are likely to be expensive).
What is your application that requires 40A at 100kHz? There might be a better way than using rheostats to provide current control.
Deleted member 115935
Joined Dec 31, 1969
Thank you.
looks like your actualy after a FET ,
but remember the power law power = I * I * R , at 40 amps thats a lot of heat even into 1 ohm,..
DickCappels
Joined Aug 21, 2008
10,661
Can you tolerate a little distortion of the waveform, and will the frequency be constant? Can you specify the granularity you need (for example, 1% steps)?
ronsimpson
Joined Oct 7, 2019
4,908
I have used adjustable power resistors. Not easy to adjust and does not have a knob. Up to 1000 watts.
This next one you can not afford. It adds a easy way to adjust.
Here is what I am looking for. I found these at digikey.com under "Rotary Potentiometers, Rheostats" Go to the link and look under "power" and then select 100 watts to 1000 watts to remove the little parts.
All of these are not good at high frequencies. I think 100khz is a little too high but worth a try.
You would have to look at the inductance of the rehostat. The corner frequency will be fc= 1/(2*PI*R*C). Fc is defined as when the out put is -3db down or 70.7% or sqrt(2) down from 0db.
You should also be able to use an electronic load.
https://mfjenterprises.com/collections/dummy-load Although not variable, they do offer a high frequency dummy load of 50 ohms. I used one of the bucket varieties for a 1000 W 13.56 MHz system.
