Is there a better way of doing this.
It is to power 6 3watt led lights with a voltage of 3.3 volts eachIs there a better way of doing this.
Thank You
Could you show me a Diagram, Please
How are the LEDs connected?It is to power 6 3watt led lights with a voltage of 3.3 volts each
You need 4 AA batteries in a 2s2p configuration.I want to double the current to keep the batteries in longer
The LEDs will be each connected in parallelHow are the LEDs connected?
Personally, I'd use Li-ion batteries.
Each with their own current limiting resistor?The LEDs will be each connected in parallel
Thank You, SirEach with their own current limiting resistor?
The nominal voltage of a Li-ion battery is 4.2V. You can run them down to around 3.5V. Typical capacity is about 2Ah for 18650's. If you go that route, be mindful of counterfeits.
If space is an issue, 18500's are closer to the length of AA batteries. Available capacity is closer to 1.5Ah.It is for a rectangle box light fixture I am making
